Setting up a weather-based irrigation system has been a fantastic project for optimizing water usage in my garden. I wanted to share my experience and some tips for anyone looking to do the same!
Why Weather-Based Irrigation?
I’ve always been conscious about water conservation, especially during dry seasons. Traditional irrigation systems often waste water by running on fixed schedules, regardless of actual weather conditions. By integrating weather data, I can adjust watering times and durations based on real-time conditions like rainfall, temperature, and humidity.
Tools I Used:
- OpenWeatherMap API: For accessing current weather data.
- **Python Libraries:**包括
pyETofor calculating evapotranspiration andrequestsfor fetching weather data. - Smart Sprinkler System: Controlled via Home Assistant with Sonoff switches.
How It Works:
- Data Collection: The system fetches weather data every hour, including temperature, humidity, and rainfall.
- Evapotranspiration Calculation: Using the Penman-Monteith equation, I estimate how much water is lost from the soil through evaporation and plant transpiration.
- Adjust Irrigation: Based on the calculated evapotranspiration and recent rainfall, the system adjusts the watering duration. If it’s been raining, the system skips or reduces watering.
Challenges and Solutions:
- Initial Setup: Integrating all components was a bit overwhelming, but breaking it down into smaller tasks made it manageable.
- Weather Accuracy: Ensuring the weather data was accurate for my specific location was crucial. I found that using a local weather station’s data improved reliability.
Tips for Others:
- Start small. Begin with one zone and expand as you become comfortable with the system.
- Regularly check and calibrate your sensors to ensure accurate readings.
- Consider using a virtual queue system to manage watering schedules dynamically.
I’d love to hear about others’ experiences with weather-based irrigation systems or any tips you might have! ![]()
