Weekend Project: Automating My Outdoor Lights
This weekend, I decided to tackle a project I’ve been putting off for too long—automating my outdoor lights. I’ve got a mix of Govee and Fibaro devices, and while they’ve been working, they’re not quite as seamless as I’d like. Let me share my journey and some tips I picked up along the way!
The Goal
I wanted my outdoor lights to do a few things:
  • Turn on at dusk and off at dawn.
  • Adjust brightness based on motion detected at night.
  • Look cohesive with the rest of my home’s lighting setup.
The Setup
I’ve got a mix of Govee RGBIC strips and Fibaro wall plugs. The Govee strips are great for ambiance, while the Fibaro plugs handle the more practical lighting needs. I also have a Trådfri motion sensor that I wanted to integrate into the mix.
The Challenges
  1. Motion Sensor Calibration: Getting the motion sensor to work reliably was a bit of a pain. I had to adjust the sensitivity multiple times to avoid false triggers but still catch actual movement.
  2. Brightness Transition: I wanted the lights to transition smoothly from 1% to 100% based on motion, but initially, the transitions were too abrupt. I had to tweak the automation rules in Home Assistant to get it just right.
  3. Color Consistency: Matching the color temperatures between the Govee strips and the Fibaro plugs was tricky. I ended up using a combination of custom scenes and manual adjustments to get everything looking cohesive.
The Solution
Here’s what worked for me:
  1. Motion Sensor Automation: I set up an automation in Home Assistant that triggers when the motion sensor detects movement. It adjusts the brightness of the lights based on the time of day and the current lighting conditions.
  2. Custom Scenes: I created a few custom scenes in the Govee app to handle different lighting modes—like a soft glow for evenings and a brighter setting for when I’m entertaining guests.
  3. Regular Maintenance: I realized that outdoor lights need regular maintenance. I now have a routine to check the bulbs and sensors every few months to ensure everything is working as it should.
Lessons Learned
  • Start Small: Don’t try to automate everything at once. Start with one area and gradually expand as you get comfortable.
  • Experiment: Don’t be afraid to tweak your settings and see what works best for your space.
  • Documentation: Keep track of what you’ve done. It makes troubleshooting much easier down the line.
Automating my outdoor lights was a great project, and I’m thrilled with the results. It’s amazing how a little bit of setup can make such a big difference in how my home looks and feels. If you’re thinking about tackling a similar project, I highly recommend it!
Happy automating! :rocket:
