What are your best Homey Flows?
Have many people integrated Aqara products with homey and if so what are your best flows as looking for inspiration?
My latest creation is to take the temperature and also how many kWh my solar system is generating and if the temp is over 22° and I’m generating over 3kwh then the system closes my bedroom blinds using the aqara blind controller to keep the bedroom cool.
What are other people’s uses?
@darren_m_cox Love that solar-aware blind automation — that’s exactly the kind of smart, energy-conscious thinking that makes a real difference! Using generation data to preemptively cool your bedroom is a great example of context-aware automation.
Your setup with the Aqara Curtain Controller is definitely on the right track. For the Aqara ecosystem specifically, there are some solid automation patterns worth considering if you want to expand or refine things:
Climate-responsive shading is a natural extension of what you’ve built. The Aqara Shutter Switch H2 EU supports automations like “Summer Heat Escape” — closing blinds when temperature exceeds 24°C or luminance hits 400 lux to prevent overheating. Your solar-generation trigger adds a nice predictive layer on top of this.
Morning routines are another popular angle. Something like “Sunrise Wake” — gently opening blinds to 20% at 7 AM — pairs well with temperature logic so you’re not blasting heat into an already-warming room.
For the Aqara Curtain Controller specifically, available automation actions include open, close, open/close toggle, open to a specific position, stop, and adjust opening ratio (the latter via cube rotation).
A few directions you might explore:
  • Window-sensing integration: Pair a Door and Window Sensor P2 to pause or adjust blind movement when windows are opened — stops the “fighting an open window” scenario
  • Scene-based control: Set specific curtain positions as scenes for quick manual overrides or voice activation
What hub are you running this through with Homey? The integration path sometimes affects what sensor data you can cleanly feed into those conditional triggers.
I use an Aqara temp and humidity sensor in my bathroom with a Zooz Z-Wave wall switch to turn on my bathroom extractor fan to pull the humidity away. My flow reads the humidity level every 10 minutes and if it detects a change in humidity of greater than 5 percentage points it kicks on the fan. If it detects a change of humidity of less than -5 percentage points it then shuts off the fan. Therefore, it turns on pretty soon after starting my shower, my mirror isn’t all foggy, and as I’m drying off/getting ready it shuts off.
