Which kind of automation do you associate to your smart switch (h2). I like to have it behave liek a normal switch, up to turn it on, down to turn it off, and oddly enough only the lower buttons can have further functionalitues. Long press and double press. I normally do dimming there. 75%, 50 %, 25%, 5%. Anything else seems like it won’t be very intuitive. What else do you guys usually put there ?
I use the H2 in my kitchen to bring on the lights at either end of it, but I’m also stuck with ideas on what to use the other buttons for. saying that an idea has just popped into my head. I wonder if I can use one of the bottom buttons to trigger the pet feeder to dispense food. I’m gonna try that out. Your post may of just helped me think of something
It kinda depends on where the switch is located. My H2 is at a desk near windows so my top switch controls the lights over the desk and the lower button is used to control the Matter over Thread blinds around the desk.
I keep the single presses predictable, then use double-press for room-level scenes that are still easy to remember: lower double-press for all lights off, and upper double-press for a bright cleaning scene. Long-press feels best for continuous controls such as blinds or dimming, while anything safety-critical stays out of hidden gestures.
In both my locations where I have switches, I also have two different kinds of bulbs.
One press toggles one set of lights, double press toggles the other. Hold toggles both. Then a twist to the right HA determines if either are on, if they are the lights brighten. If only one is on, only that one changes. The opposite for light turn.
To my surprise it works too. Not because of the tech, more because of my ineptitude
right now I have my lower button (the non-relay one) on H2 toggle the light to 80% brightness on one click, 100% brightness on double-click. the other button is unused, it’s supposed to be a backup button in case the matter server isn’t reachable.
but I would love to make it like OP said: lower button light on, upper button light off. also if the led would follow the last button pressed that would be awesome. and decoupled relay in matter mode, of course.
I have the robot vacuum clean the specific room when double pressing the lower button. For example the switch in the living room lets the robot vacuum clean the living room. The switch in the hallway next to our door is programmed to clean the hallway and the other button on it is programmed to run a full vacuum cleaning
how exactly do you do dimming with 4 brightess options? long press until satisfied or multi click? I did the opposite: one click turns on the light at 80% (brightness which the wife prefers) and two clicks in a row turn on the light at 80%->100%. While you are clicking you can see the brightness trigger to 80 on the first click and then goes up to 100 on the second click. I like this UX, feels intuitive for me. Wife does not care about the second click, she just wants the upper button to turn off the light and in matter mode this is not doable in a good way. I keep asking Aqara to give us matter-decoupled. Aqara users keep telling me to switch to Zigbee hehe
