What happened to UWB on SmartThings
Has anyone got in the uwb feature to work on the u300 through SmartThings because it was supposed to be added in May and I don’t see it anywhere in the app
I believe the UWB is currently exclusive to the U400. The U300 doesn’t have the hardware for UWB.
The UWB in smart locks was introduced as Apple-exclusive feature and the UWB feature was later added to high end Samsung. But you still need the U400 for that feature
You are correct, UWB is only present on the U400 and not the U300. Although he is correct that it was stated in the footnotes that this feature would arrive for Samsung devices in Q2 2026. According to the product manager, manufacturers are struggling to make this feature work without significantly affecting either the device’s battery or the locks battery due to the fact that devices use different UWB components. I understand why this could be an issue for Google Wallet, but as for Samsung, UWB models are limited to flagship models and components should be relatively uniform.
