What makes an Aqara automation dependable enough to leave alone?
The automations that interest me most are the ones that quietly solve an everyday problem and still make sense when something goes wrong.
For an Aqara lighting or presence automation, I would start with three design questions: what triggers it, what ends it, and how someone can override it without opening an app. I would also want to know what happens if the sensor goes offline or someone changes the light manually.
Which small design choice has made the biggest difference in your setup: an off delay, a second sensor, a physical button, or something else? Please share the device, the problem, and the change that made it dependable. Examples of an automation you simplified or abandoned would be useful too.
@jeremiahelight Hi there! It is great to see such a thoughtful discussion on building reliable smart home automations. You’ve hit on the exact pain points that separate a “cool gimmick” from a truly useful smart home feature.
Based on community experiences and product capabilities, here are a few design choices that significantly boost dependability:
1. Leveraging “Absence” Timers for Presence Sensors
For presence-based automations (like the Aqara Presence Sensor FP2 or FP1), the biggest reliability booster is often the “Absence for some time” condition. Instead of relying solely on motion, you can set a duration (e.g., 10 minutes) before turning off lights or AC. This prevents the system from reacting to a brief pause in movement. The FP2, for instance, distinguishes between “Presence” and “Absence” statuses, allowing for smoother transitions. The FP1 also supports configuring durations for “Presence of People for a Certain Duration,” which is excellent for energy-saving scenarios like turning off AC after an office area is empty.
2. Physical Overrides via Smart Switches
To answer your question about overriding without an app: using Aqara Light Switches (like the Light Switch H2 Horizontal) is a game-changer. You can decouple the relay to turn the switch into a wireless controller or use it in its standard mode. This allows users to manually toggle lights via the physical button, regardless of what the automation is doing. This ensures that if a sensor goes offline or an automation behaves unexpectedly, the user still has direct, tactile control.
3. Combining Sensors for Robustness
Using a second sensor, such as combining a Motion Sensor P2 with a Light Sensor, can prevent false triggers. For example, you can configure an automation where lights only turn on if motion is detected and the brightness is below a certain lux level. This ensures lights don’t turn on during the day when they aren’t needed, making the automation feel more “natural” and less intrusive.
4. Ensuring Stability
Finally, for any automation to be truly dependable, ensuring stable connections is key. If automations sometimes fail to trigger, it’s often worth checking internet stability, firmware updates for the Hub and devices, and ensuring all devices in the chain are powered on and functioning correctly. Restarting the app or device can also resolve temporary glitches.
What do you think? Do you prefer the tactile feel of physical switches for overrides, or do you find configuring complex presence timers more reliable? I’d love to hear how you’ve balanced these elements in your own setup!
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
Hello, and welcome to the forum.
My tutorials cover the kind of examples you are looking for. This is an introductory guide to building a smart home using Aqara. Pay special attention to Lesson 1 and its supplement; they will give you a clear understanding of how the Automation 2.0 logic works. Automation 2.0 Tutorial Collection - Lesson 1 report
I recently added a P100 vibration sensor to my doorbell. This worked well but when someone smashed the door, it was ringing. So I tweaked the automation a little and now check that the door was closed for 10 seconds before the vibration is detected and only ring the chime in that case. This completely eliminated these these cases.
Here are some pictures of the setup (still without the check):
