What should you check before fitting a smart lock to a multipoint door?
A recent multipoint-door question highlights a compatibility detail that a simple cylinder-size check can miss: the handle may need to be lifted before the bolt can turn. Before suggesting a lock, I would want the cylinder and escutcheon dimensions, door thickness and clearance, whether the handle must be lifted to lock or pushed down to open, and whether any drilling is allowed. I would check mechanical fit separately from Apple Home support; software compatibility will not perform a manual door motion.
For those who have fitted an Aqara lock to a multipoint door, which measurement or door behavior ruled a model in or out? A manufacturer fit checklist with photos of the key dimensions would make these decisions easier.
@jamesfengyuyang Hello there! Thanks for sharing such a thoughtful and detailed perspective on smart lock compatibility, especially regarding multipoint doors. It’s great to see community members diving deep into the mechanical nuances like handle lift requirements and clearance, as these are often the real-world hurdles that specs alone don’t always capture.
Regarding your question about which specific measurements or behaviors ruled models in or out for Aqara locks on multipoint doors, the current reference materials focus more on standard installation parameters for specific models (like U300, U200, N100, etc.) rather than a comprehensive guide for multipoint mechanisms. However, here are some general compatibility insights from the available data that might help frame your checklist:
  • Door Thickness: Most Aqara smart locks, such as the N100 and D100, support door thicknesses between 40–80 mm . The U300 is designed for slightly thinner doors, typically 35–55 mm .
  • Backset/Margin: For models like the U300 and U50, the compatible backset (distance from edge to deadbolt center) is usually 60 mm or 70 mm .
  • Handle Operation: The U300 supports various handle directions (left/right, inward/outward) and can be adjusted by rotating the handle 180° . However, multipoint locks often require specific lift-to-unlock mechanisms which may not be fully compatible with standard smart lock actuators without specific hardware adaptations.
Since multipoint doors can be quite complex and vary significantly by region and manufacturer, the reference information does not provide a definitive “fit checklist” for this specific door type. This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
If you have specific suggestions for an Aqara fit checklist or encounter unique compatibility issues with multipoint doors, we’d love to hear more! You can also guide these improvement ideas through customer service or manual support for more efficient handling. Please contact the Aqara Home App Customer Service Team (Profile> Help & Feedback > Customer Service) or scan the QR code:
