What still works when a smart lock's hub or internet is down?
Recent questions about setting up a lock before the network is ready made me think that “works offline” needs a more precise test. I would check four paths separately: unlocking locally from outside, exiting from inside, seeing lock status in Aqara Home or Apple Home, and any automations triggered by a lock event. Those paths may have different dependencies.
A useful drill would compare an internet outage with a powered-down hub, while keeping another reliable way into the home available. Record what still works in each case and what recovers automatically when service returns. Which fallback path do you test first, and have you seen the two outage cases behave differently?
Most smart locks that I have tested do not require an active internet connection to lock and unlock the door when physically present. Remote access is an entirely different beast altogether if either your internet or the hub itself goes offline, then you lose access while away.
That’s right. Most smart door locks establish a Bluetooth connection at close range. It doesn’t matter if the hubs, Wi-Fi, the Internet, or Thread go down.
Generally speaking, with Aqara equipment - and I’m not talking specifically about locks here the internet should not have any impact on the internal performance of your system. ( i’m talking zigbee here )
If your entire Wi-Fi network goes down, this could potentially cause some issues, but generally only when automations are running across different hubs. Even then, it would only be a problem if one of the hubs involved relied on Wi-Fi connectivity.
I try to keep all of my automations local to each individual hub and the devices connected to it. For example, my master bathroom has its own Aqara E1 Hub, with several devices connected to it - lights, wireless switches, a leak sensor, temperature sensor, relay for the fan, etc. You get the picture.
All of the automations for the bathroom remain local to the E1 hub. Therefore, even in the event of a complete loss of internet or Wi-Fi, the bathroom continues to operate normally, with all of its automations remaining unaffected.
I’ve designed my whole home around this principle, keeping devices and their automations as local as possible.
Thread is a different scenario, however, and works using a different logic.
