When is the Aqara W200 available in the uk and would it work with the fcu units in uae
@mohammed_sadiq I don’t have any official info here on when the Thermostat Hub W200 will be available in the UK/UAE, so I can’t give an accurate release timeline based on the reference material provided.
On the FCU compatibility part: the W200 is designed for low‑voltage (24V) HVAC systems and supports typical thermostat terminals like Rc, C, W/W1, Y, G (and similar) wiring setups. So it may work only if your FCU setup in the UAE is controlled via a 24V thermostat-style interface that matches those terminals. If your FCU uses other control methods/voltages, it may not be compatible.
Also, if your system has terminals like 1/2/3/4, A/B/C/D, Water/H20, or L1/L2/110/120/240V, that’s flagged as not compatible for the W200.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully. Original post link: N/A (not provided)
If you can share a photo of the wiring/terminal labels on your current FCU thermostat or control board, folks here can help you sanity-check it.
For availability and region-specific compatibility confirmation, please reach out here:
This will be more efficient. If you do not have an Aqara Home account, Please click here to create a ticket. Sorry for the inconvenience.
