When the Aqara app says a sensor is offline but it still responds elsewhere
A recent leak-sensor report describes brief “disconnected” notices in Aqara Home, including for a sensor beside the hub. The owner did not see the same false-disconnect notices in HomeKit or Home Assistant, and a leak alert arrived promptly in a check after reconnection. That is useful evidence, but it does not yet tell us whether the sensor actually lost its radio link, the hub missed a report, or the app displayed a stale status.
If this happens, which timestamps or logs can separate those possibilities without resetting or re-pairing the sensor? I would compare the Aqara Home disconnect/reconnect times with the hub’s online status, each platform’s last sensor event, the sensor and hub firmware versions, and whether other accessories on the same hub changed state at the same time. I would avoid relying on an unsafe water test just to investigate a status notice.
It would help if Aqara Home distinguished “no recent device report” from “hub unavailable” and “app/cloud sync delayed.” Has anyone found a reliable way to make that distinction today?
@jamesfengyuyang Hi there! :wave:
Wow, that is a incredibly sharp and detailed analysis of the “ghost offline” phenomenon with Aqara sensors. You’ve hit on a classic pain point for smart home enthusiasts: the discrepancy between local Zigbee reliability and cloud/app status updates.
While the Aqara Home app doesn’t currently provide granular logs to distinguish between “no report,” “hub unavailable,” and “sync delay” directly in the UI, your troubleshooting approach is spot on. Based on common community experiences, here are a few steps you can take to isolate the issue without resetting your device:
  1. Check Hub Firmware & Connection: Ensure your hub is online and its firmware is up to date. Sometimes, a stale hub connection can cause app status lag even if the local Zigbee link is fine.
  2. Signal & Interference: Even if the sensor is near the hub, metal surfaces or Wi-Fi interference can cause brief dropouts that the app might register as offline before re-establishing. Try moving the hub slightly or ensuring the sensor isn’t on a metal surface.
  3. Cross-Platform Verification: Since you mentioned HomeKit/Home Assistant didn’t show the disconnect, this strongly suggests the issue is with the Aqara app’s sync or the hub’s reporting to the cloud, rather than a true radio link failure. Ensure your Apple Home Hub and Aqara Hub are on the same LAN if you’re using HomeKit, as network segmentation can cause sync issues.
  4. Reboot the Hub: A simple reboot of the hub can clear up temporary glitches in the local network bridge.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
It would be great to hear if anyone else has found specific log locations or workarounds for this! If you do find a reliable way to distinguish these states, please share it with the community.
If you need further assistance or want to suggest this feature improvement to the product team, please contact the Aqara Home App Customer Service Team (Profile> Help & Feedback > Customer Service) or scan the QR code:
