@mattervietnam Hi there! It’s great to see you diving into the world of smart home automations with Aqara sensors. You’ve highlighted some excellent use cases, from turning on hallway lights to securing your home when you’re away.
Based on the technical specifications and comparisons available, here is how the different Aqara Door and Window Sensor models stack up regarding your questions about Zigbee vs. Thread, reliability, and battery life:
Zigbee vs. Thread: Which is better for you?
The choice largely depends on your ecosystem and hub setup:
Zigbee Options (Door and Window Sensor & Door and Window Sensor T1):
These sensors use the Zigbee protocol (1.2 for the standard model, 3.0 for the T1).
They require an Aqara Hub to function.
They are compatible with Apple HomeKit and the Aqara Home App.
Reliability: Zigbee is known for its stability and low latency in mesh networks, making it very reliable for daily automations like triggering lights.
Thread Option (Door and Window Sensor P2):
This model uses the Thread protocol combined with BLE and supports the Matter ecosystem.
It requires a Matter Border Router Hub (such as the Aqara Hub M3) to connect to your network.
Ecosystem: It offers superior interoperability across multiple platforms, including Apple HomeKit, Google Home, Alexa, Samsung SmartThings, and Home Assistant.
Reliability: Thread is designed for low power and high reliability, similar to Zigbee, but with the added benefit of Matter compatibility for seamless cross-platform automation.
Battery Life
Zigbee Models (Standard & T1): Both use a CR1632 button battery. These are small, coin-cell batteries that typically last a long time due to the low-power nature of Zigbee and the sensor’s infrequent transmissions.
Thread Model (P2): Uses a CR123A battery[“content_id”:2"]. This is a larger battery, which generally provides longer life and consistent power for the Thread radio, though exact longevity depends on usage frequency.
Common Issues: Delays and States
If you experience delayed notifications or incorrect states with Zigbee sensors, it is often due to distance or interference:
Sensor-to-Magnet Distance: Ensure the sensor and magnet are within 22mm of each other for the Standard and T1 models. The P2 allows configurable distances (≤10mm, ≤20mm, or ≤30mm).
Hub Distance: If the Aqara Hub is too far from the sensor, communication may drop. Moving the sensor closer to the hub or ensuring the hub is centrally located in your mesh network can help.
Recommendation
For Multi-Platform/Matter Users: If you want to integrate with Google, Alexa, and Home Assistant seamlessly, the Door and Window Sensor P2 is the future-proof choice due to its Thread and Matter support.
For Standard Aqara/HomeKit Users: The Door and Window Sensor T1 is a robust, widely compatible option that works well with most Aqara hubs and Apple HomeKit.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
Have you already chosen a hub for your setup? That might help narrow down the best sensor for your specific needs!
Hello
I have used a lots of sensor, but for Window and Door the best solution are offers from Maco Company and are Matter over thread. i used with Aqara Hub M 100 and you’ll create a lots of scene combined with device Aqara and others device third party
I have been using the Aqara Door and Window Sensor and Aqara Door and Window Sensor T1 for several years. I have installed them on all entry doors, the outdoor shed door, and every window in my house.
When the Aqara Door and Window Sensor P2 was released, I started replacing some of my older sensors with this Matter-over-Thread model. Unfortunately, the P2 hasn’t been very reliable, as it occasionally loses its connection.
I have now started gradually replacing all three models with the Aqara Multi-State Sensor P100, running in Zigbee mode . I use two Aqara Hub M3 units in my smart home setup.
My Everyday Automations
I use the sensors for several simple but useful automations:
Outdoor shed: The light automatically turns on when the door opens and off when it closes.
Main entrance: If the front door stays open for three minutes, I receive a notification in the Aqara app.
Daughter’s room: If the patio door is opened after 9:00 PM, I receive a notification in the Aqara app.
Windows: I use the Aqara app to check whether any windows in the house are open or closed.
Planned automation:
Window and heating control: During winter, I plan to create an automation that automatically turns off the electric panel heaters if a window has been left open for approximately five minutes. This should help reduce unnecessary energy consumption when airing out rooms.
My Thoughts
Overall, I have been very happy with the Aqara Door and Window Sensor and Aqara Door and Window Sensor T1 . Both models have worked reliably for several years.
The Aqara Door and Window Sensor P2 has been more disappointing due to occasional connectivity issues.
I’m now gradually upgrading all my door and window sensors to the Aqara Multi-State Sensor P100 in Zigbee mode , replacing both the older Zigbee models and the Matter-over-Thread P2.
For me, door and window sensors are not just about security. They are also a simple and practical way to make everyday life easier through smart home automations.
