Which door lock is suitable for modern Dutch home with multipoint lock
So I’m based in The Netherlands and I have trouble finding a suitable lock for a multipoint front door. Basically the hinge both on the inside and outside requires a manual pull upwards before the final lock turn can initiate. Conversely it requires a manual push downwards before the full opening can be done.
I had the Smart Lock U200 and while it technically stated that it should work and sometimes it did, in practice it didn’t work and broke down 3 times before even the shop said “hey, shall we just give you your money back this time?”.
I’m thinking maybe a fully integrated lock instead of a bolted on lock, but my door is aluminum so I can’t drill in it or anything. And I need Homekit integration. Any recommendations?
I don’t believe there are any smart locks which lift the handle for you, but I could be incorrect. I currently have Nuki pro (not Aqara!) installed on a UK multipoint door lock but need to manually lift and push down the handle when locking and opening the door.
I’ve linked it to an Aqara door sensor so it locks automatically when the door closes but it still requires the handle to be lifted before it’s able to lock properly
I agree that lifting the lock will be impossible. So I guess my question is more of a question about locks knowing about this and working around it. Yes, the U200 had a “pause” moment but it always felt so sketchy and cheap and people including myself weren’t always on time which led to the cylinder of the lock itself to stop working 3 times in a few weeks time. Eventually you hear the motor spin but not grabbing the mechanism.
But even before that, if you lifted up the handle slightly too late, the lock would want to initiate the final turn and it couldn’t which led to a mechanical noise coming from the lock, as if it broke through its own cog wheel mechanism somehow, which was fully plastic I found out.
I’ll take a look at the Nuki pro, but was hoping other Aqara options would be more suitable than the U200 to be honest.
Sorry, maybe someone else can help re. Aqara locks! For Nuki, I sometimes don’t lift the handle in time as I haven’t set a delay between the door sensor closing and locking, but I’ve set an automation in HomeKit where if it’s unable to lock it’ll try again in a couple seconds. I don’t get the impression that it’ll break the Nuki as it’s pretty sturdy. I’d be interested to see if you can find a suitable option, as I agree how I’m doing it currently isn’t perfect!
