Why did Aqara develop the Smart Lock U600 specifically for the UK market?
You are correct in that the unlock/lock mechanism is connected to the external handle, when dis-enguaged the handle moves freely downwards so you cannot unlock / open the door, you can still lift to enguage multiplcks.
When enguaged the external handle will unlock the multipoit locks and main sash lock and open.
There is no external power connector, it only runs on battery but can be temporarly powere though an external USBC connectoor on the outside handle directly at the bottom also where the mechanical key is.
When fitting these the barrel lock is removed and not used, you should know this as some concider this as a security risk, personally I do not.
You can link this lock with an aqara door camera and have the unlock button on the camera feed to allow remote entry.
You’ll have to forgive my lack of knowledge on locks, but from a security point of view, my assumption is that the barrel lock is purely responsible for the key mechanism that engages the bolts in the door (dead bolts and hook bolts? I have hooks top and bottom and a dead bolt centrally for example). So providing that the lock still engages all of these bolts, there should technically be no security risk?
I assume the U600 has some sort of mechanism that essentially replaces the barrel lock however? You also say that there is access for a physical key, is this essentially an Aqara key specific to this mechanism? So in a way it’s a replacement barrel lock?
Lastly, given that the barrel/lock/handles is replaced, is there or are there any plans to gain any sort of certification or accreditation? From my limited understanding, there are standards and certifications that are generally applied to locks in the UK which cover a range of scenarios and point to how secure they are considered. (BS/TS/SS etc.) This could potentially have an effect on home and contents insurance policies for example, as I recall they asked me what type of locks I had installed when I took out the policy.
I appreciate the explanations by the way! I have just been given access to the trial, so looking forward to seeing and testing how it works myself in due time :slight_smile:
Hi, yes, there is such a key; I call it the “emergency” key.
Ok so looking at videos of this lock / handle combo online, I have one simple question. Can the handles be reversed…
As in the handles point to the right on the keypad side. Where in the UK, at least where I live, most handles are fitted to the right side of the door and have handles that point to the left
Instead of
If that makes sense
I struggled in the past trying to find locks for my upvc doors but even though i did find some its great to get more and better choices
Hi from Ireland :ireland:, are there any plans to bring the U600 here? As mentioned above, this style of door is just as common in Irish homes as in the UK, so it looks like a natural fit. Matter over Thread is a big draw for me too, since it would slot straight into my Home Assistant setup. I’d happily test one if an Ireland trial ever comes up!
Does anyone know the price or when it will be released at all? I’ve tried to find it on YouTube too but as there are no reviews yet it is hard to find. Does anyone have. Good one to share at all?
I have just seen this post :rage: as I have decided to go down the rabbit hole of buying Aqara products for my Home assistant house…
I have 2 Yale Connex L1 locks and they are absolute garbage!!! - I installed both and also have the 2 hubs you need to connect them and after many months of testing and tinkering I have had enough, so I hope the Aqara locks will be better and not have the same annoying issues like the Yale ones…
The worst feature, is having to lift the handle when the door is closed or it goes mental or the other thing is the auto locking timeframe which ais a royal pain!!!
A very interesting read for a newbie here thank you
I hope this lock is released in other regions as well; it will be very useful for users with uPVC doors. There are very few good locks on the market suitable for this type of installation.
I’ve received my U600 and really like how it works so far. I won’t go into too much detail about the product itself as I’m conscious this is an early-access unit and I’m not sure how much we’re permitted to discuss publicly.
However, I do have one concern that is currently stopping me from installing it permanently on my main entrance door: physical security and certification .
For comparison, I currently use an Aqara U200 on this door. One of the things I’m comfortable with about the U200 is that it operates the existing lock and cylinder, so the original physical security of the door remains in place. In my case, that’s an independently tested cylinder with a TS 007 3-star rating.
The U600 takes a different approach. The existing cylinder is removed, so the U600 itself becomes a much more significant part of the door’s physical security. Rather than retaining my existing certified cylinder, we’re now relying on the U600’s mechanism, including its emergency key system, to control access to the multipoint locking mechanism.
That’s the part I’d really appreciate some clarification from Aqara about.
1. Emergency keys
Are the two emergency keys supplied with each U600 uniquely keyed to that individual lock?
I assume they are, but given that these provide a mechanical means of operating the lock, I’d like to confirm that different U600 units cannot be operated using the same emergency key.
2. Physical security of the key and locking mechanism
How resistant is the emergency key cylinder/mechanism to attacks such as picking, drilling or physical forcing?
More importantly, has the U600, its emergency locking mechanism, or the complete U600 locking system been independently tested or certified to any recognised UK physical-security standard?
For example:
  • TS 007
  • PAS 24
  • BS 3621 / BS 8621
  • BS EN 14846
  • or another equivalent/relevant standard
If it has, could Aqara provide details of the exact certification achieved and, ideally, the relevant certificate or test report?
If it hasn’t currently been independently certified to a physical-security standard, does Aqara intend to obtain such certification?
This is particularly important to me because the cylinder I’m removing is already independently tested and carries a TS 007 3-star rating. I don’t want to unknowingly reduce the physical security of the door by replacing a certified component with one whose resistance to physical attack hasn’t been independently assessed.
There’s also the question of home insurance .
Some UK insurers specify minimum security standards for external doors, and potentially replacing a certified cylinder with an uncertified smart-lock mechanism could affect theft cover or a subsequent claim.
I can’t actually find a specific minimum lock standard in my own Allianz policy documents, so I’m contacting them separately to get written confirmation about the U600.
However, I suspect many people buying the U600 won’t think to check this before installing it. Given that the U600 is specifically designed for UK-style doors, I think it would be useful for Aqara to clarify what independent physical-security testing/certification the U600 has undergone, or what certification is planned.
I’m very keen to use the U600 permanently. I just want to be confident that moving from the U200 to the U600 isn’t also moving from a known, independently certified physical-security component to something of unknown physical-security performance.
@Aimer - is this something you can answer, or find out?
