Wyze Cam Motion Detection Issue Solved
Hey everyone, I wanted to share my experience with the Wyze Cam v3 motion detection feature. I recently noticed that my camera wasn’t capturing motion events properly. It would either miss the motion entirely or record it too late, which was frustrating, especially for outdoor use. After some research and troubleshooting, I found a solution that worked for me!
First, I checked the camera’s settings to ensure motion detection was enabled and properly configured. I adjusted the sensitivity levels and made sure the camera wasn’t in a low-power mode. Then, I tested the camera in different lighting conditions to see if that affected the motion detection accuracy.
What really made the difference was updating the camera’s firmware to the latest version. Wyze often releases updates that improve functionality and fix bugs, so it’s worth checking for updates regularly. After the update, the motion detection became much more reliable!
I also set up a routine using the Wyze app to send notifications to my phone whenever motion is detected. This way, I don’t miss any alerts, and I can review the footage immediately if needed.
If anyone else is having trouble with motion detection on their Wyze Cam, I recommend trying these steps. It’s always a good idea to ensure your firmware is up to date and your settings are optimized for your specific use case. Let me know if you have any questions or if there’s another solution that worked for you!
Happy smart home tinkering! :rocket:
