Wyze Cam Motion Detection Tips and Tricks
Hey everyone, I wanted to share my experience with setting up motion detection on my Wyze cameras. I recently installed two Wyze cams to monitor my front door and backyard, and I must say, getting them to work seamlessly was a bit of a journey, but definitely worth it!
Initially, I faced some issues with the motion detection being too sensitive, especially with the wind causing false alarms. After some research and trial and error, I found a few tips that made a world of difference. First, adjusting the camera’s angle to avoid direct sunlight was crucial. Second, using the Wyze app’s advanced settings to fine-tune the motion sensitivity and exclude certain areas helped reduce those pesky false triggers.
I also discovered that placing the cameras slightly higher and away from direct wind paths made a significant impact. Plus, enabling the built-in motion blur reduction feature in the app helped with the shaky footage caused by wind. It’s amazing how a little tweaking can make such a big difference!
For anyone else setting up Wyze cams, I’d recommend spending some time in the app’s settings to customize the motion detection to your specific needs. Don’t hesitate to experiment with different placements and settings—it’s all about finding the right balance for your space. Happy monitoring everyone! :male_detective::male_sign:
