I recently encountered a frustrating issue with my Wyze Cam Outdoor base station, which suddenly disconnected from my Wi-Fi network. After hours of troubleshooting, I discovered that the problem was related to my router’s WPA3 encryption being enabled. Here’s how I resolved it and what you can do if you’re facing the same issue.
The Problem
After a firmware update on my eero mesh router, WPA3 was automatically enabled. This caused my Wyze Cam Outdoor base station to lose its Wi-Fi connection, while all other devices, including V2 and V3 cameras, remained unaffected. This inconsistency was perplexing, but I was determined to find a solution.
The Solution
After some research, I found that Wyze base stations are not compatible with WPA3 encryption. The fix was straightforward: I simply disabled WPA3 on my router. Once WPA3 was turned off, my Wyze Cam Outdoor base station reconnected without any issues.
Key Takeaways
- Check Your Router Settings: If your Wyze Cam Outdoor is having Wi-Fi issues, the first step is to check if WPA3 is enabled on your router. Disabling it may resolve the problem.
- Firmware Updates: Be cautious after router firmware updates, as they can sometimes introduce settings that conflict with existing devices.
- Compatibility Issues: Not all devices support the latest encryption standards. It’s essential to verify compatibility before enabling new features on your router.
Additional Tips
- If you’re integrating multiple smart devices, ensure that your router’s settings are optimized for all devices. Sometimes, a single setting can cause widespread connectivity issues.
- Regularly monitor your router’s firmware updates and adjust settings as needed to maintain compatibility with your smart home ecosystem.
I hope this guide helps anyone facing similar issues with their Wyze Cam Outdoor. Let me know if you have any questions or if there are other topics you’d like me to cover!
