Hi everyone, I wanted to share a quick fix I found for the Wyze Cam Pan 360° rotation limit tabs breaking off. I’ve had my Wyze Cam Pan for a while now, and it’s been a great addition to my smart home setup. However, recently I noticed that the tabs preventing the camera from rotating too far had broken off. This caused the camera to go haywire during tracking and made it difficult to use the app for manual adjustments. After some research, I stumbled upon a helpful YouTube video that demonstrated a simple yet effective solution. The idea was to use a small plastic bracket to reinforce the tabs and restore the camera’s rotation limits. I had to be careful while applying the fix to avoid damaging the camera’s internal components, but it turned out to be much easier than I anticipated. Here’s a quick summary of the steps I took: 1. I cleaned the area around the broken tabs to ensure a good bond. 2. Using the plastic bracket, I positioned it over the tabs and secured it with some strong adhesive. 3. I tested the camera’s rotation to ensure it was back to normal. The fix worked perfectly! The camera now tracks smoothly without over-rotating, and the app controls are responsive again. I was a bit worried about voiding the warranty, but since the fix was so straightforward and didn’t involve any modifications to the camera’s internals, I think it’s safe. For added protection, I also picked up an outdoor weather shield from Amazon to prevent any future damage from environmental factors. It’s a small investment that gives me peace of mind knowing my camera is well-protected. If anyone else is dealing with this issue, I highly recommend giving this fix a try. It’s a quick and cost-effective solution that brings your Wyze Cam Pan back to full functionality. Let me know if you have any questions or if you’ve found another way to solve this problem!
