Hey everyone, I wanted to share my experience with the Wyze Cam Pan connectivity issues I’ve been facing. While the Cam v2 connects instantly, the Wyze Cam Pan has been taking quite some time and multiple attempts to connect via the app on my phone. I thought I’d document my journey and see if anyone else has encountered similar issues or has a fix to share.
Initially, I suspected it might be a local network issue, so I tried resetting my router and ensuring the Cam Pan was within range. However, the problem persisted. I then checked for any firmware updates for the Cam Pan and the Wyze app, but everything seemed up to date.
After some research, I found that others have reported similar connectivity delays, especially in areas with dense Wi-Fi networks or older routers. A few suggested switching the Wi-Fi band from 5 GHz to 2.4 GHz, which I tried and noticed a slight improvement. However, the issue wasn’t fully resolved.
Another tip I came across was disabling any battery-saving features on the phone that might be restricting background app activity. I adjusted my phone’s settings to ensure the Wyze app could run smoothly in the background, and this seemed to help reduce the delay.
If anyone has additional tips or has found a reliable fix for this issue, I’d love to hear about it! It’s been a bit frustrating, but I’m hopeful we can find a workaround together. Let’s keep the discussion positive and collaborative!
Cheers,
