I recently upgraded my Wyze Cam v2 to the RTSP firmware and wanted to share my experience and some tips for integration with other systems. The process was straightforward—downloading the firmware, renaming it, and following the setup instructions. However, I encountered an error on one of my cameras, which I’m retrying tonight. After the upgrade, I configured the RTSP settings in the Wyze app and integrated the cameras into Netcam Studio. The setup involved defining the stream type, URL, and configuring motion detection zones. The results were impressive, with motion capture and timelapse working seamlessly. For those looking to integrate Wyze Cams with other platforms, I recommend exploring Netcam Studio for advanced monitoring and automation. If you’re using Home Assistant, ensure your setup supports HTTPS for secure access. Overall, I’m thrilled with the RTSP support from Wyze. It’s a significant enhancement for security and automation enthusiasts. If you’re considering this upgrade, give it a try—it’s well worth the effort!
