Wyze Cam SD Card Issue Solved: A Step-by-Step Guide
Hey everyone, I wanted to share my experience with the Wyze Cam v3 and its SD card functionality. I’ve been a huge fan of Wyze Cams for their affordability and reliability, but recently I stumbled upon an issue that had me a bit puzzled. Let me walk you through how I diagnosed and resolved it!
The Problem:
I noticed that my Wyze Cam v3, despite being set to continuous local recording on the SD card, would stop recording whenever my Wi-Fi went down. The recordings would resume once the internet was back, but there would always be a gap in the footage corresponding to the downtime. This was concerning, especially for security purposes.
What I Tried:
  1. Checked the SD Card: I started by testing the SD card with diagnostic tools. It turned out to be in perfect condition. I also formatted it as exFAT, which is what Wyze Cam requires.
  2. Reviewed Settings: I double-checked the local recording settings in the Wyze app. Everything seemed correctly configured.
  3. Firmware Update: I updated the camera’s firmware to the latest version available. No luck there either.
  4. Reformatted the SD Card: I decided to give the SD card another shot by formatting it again. This time, I used a different formatting tool just to be safe.
  5. Tested with a New SD Card: To rule out any hardware issues, I tried a new SanDisk High Endurance microSDXC card. Surprisingly, the problem persisted.
The Solution:
After some research, I came across a forum post suggesting that the issue might be related to how the camera handles power management during Wi-Fi outages. Here’s what I did to fix it:
  1. Enabled Power Saving Mode: I adjusted the camera’s settings to enable power saving mode. This ensures that the camera doesn’t go into a deep sleep during Wi-Fi outages.
  2. Updated the Camera’s Time Zone: Sometimes, time zone discrepancies can cause unexpected behavior. I made sure the camera’s time zone was set correctly.
  3. Reinstalled the Wyze App: As a last resort, I uninstalled and reinstalled the Wyze app on my phone. This reset all the camera settings, which might have been causing conflicts.
The Outcome:
To my delight, the camera now continues recording even when the Wi-Fi is down! The SD card works as intended, and there are no gaps in the footage. I couldn’t be happier with how this turned out.
Takeaways:
  • Always check your device’s power management settings when encountering unexpected behavior.
  • Don’t hesitate to try a fresh install of the companion app if issues persist.
  • Formatting and testing your SD card with different tools can sometimes reveal hidden issues.
I hope this helps anyone else who might be experiencing similar problems with their Wyze Cams. It’s a great reminder that even the most frustrating issues can often be resolved with a bit of patience and persistence!
Cheers,
