Hi everyone, I wanted to share my experience with Wyze cameras in Europe. As many of you might know, the default UK sockets on Wyze cams don’t work here, so I had to find a workaround. I purchased a travel adapter specifically designed for Europe, which solved the problem perfectly. It’s a small inconvenience, but it works!
I also reached out to Wyze support about this issue, and they suggested creating a forum topic to gauge interest. If enough users are interested, they might consider offering European adapters directly. If you’re using Wyze cams in Europe, I’d love to hear your thoughts or alternative solutions you’ve found!
For those who are curious, here’s a quick tip: make sure your travel adapter is compatible with both Type C and Type F sockets, as these are common across Europe. Happy hacking and let’s keep the community growing!
Best regards,
