Hey everyone,
I wanted to share a quick tip that might help others who are experiencing sound issues with their Wyze Cams. I recently noticed that my Wyze Cam was recording with a lot of static, making it nearly unusable for clear audio. After some research and troubleshooting, I found that switching to the RTSP firmware made a world of difference!
Here’s how I fixed it:
- Switch to RTSP Firmware: I updated my Wyze Cam to use the RTSP firmware instead of the default one. This change improved the audio quality significantly!
- Check Placement: I also made sure the camera was placed in an area with minimal background noise, which further enhanced the audio clarity.
- Test and Adjust: After setting it up, I tested the audio in different conditions and made minor adjustments to ensure consistent performance.
If you’re dealing with similar issues, I highly recommend trying out the RTSP firmware. It’s a simple fix that can make a big difference!
Happy smart home tweaking! ![]()
