Hey everyone, I’ve recently purchased a Wyze Cam V2 and I’m absolutely thrilled with its performance. However, I encountered a minor challenge that I thought might be worth sharing in case others are facing the same issue. I wanted to place the camera in a tree in my front yard to monitor my driveway and front porch, but the power source was a bit of a puzzle. After some research and experimentation, I found a practical solution that I’d like to share with the community.
The Challenge: The Wyze Cam V2 requires a power source, and running a power cable to the tree wasn’t feasible. I needed a portable and reliable power source that could keep the camera running without any interruptions. After some research, I discovered that using a USB power bank was a viable solution. However, not just any power bank would work—I needed one that could provide a steady power supply without frequent recharging.
The Solution: I decided to use a portable USB power bank with a capacity of 20000mAh. This size provides enough power to keep the camera running for several days without needing a recharge, which is perfect for my setup. I also made sure to choose a power bank with a built-in LED display to monitor the battery level, which has been incredibly helpful.
Setup Tips:
- Placement: I secured the power bank to the tree using a weatherproof mounting bracket. This keeps everything tidy and protects the power bank from the elements.
- Cable Management: I used a durable USB extension cable to connect the power bank to the camera. This allows me to position the camera exactly where I need it without worrying about cable length.
- Weather Protection: I applied a waterproof coating to the power bank and the cable connections to ensure they can withstand rain, snow, and other weather conditions.
Conclusion: Using a portable USB power bank with the Wyze Cam V2 has been a game-changer for me. It’s allowed me to place the camera in a location that provides optimal coverage without the hassle of running power cables. I hope this solution helps others who are looking to expand their security setup without the constraints of a fixed power source.
If anyone has additional tips or alternative solutions, I’d love to hear them! Happy tinkering everyone! ![]()
