I recently encountered an issue with my Wyze Cam v3 when trying to use it with my 2020 MacBook Pro. The camera would briefly appear and then disconnect, which was quite frustrating. After some research and troubleshooting, I found a solution that worked perfectly. Here’s how I resolved the issue:
Check Firmware Updates: I started by ensuring both the Wyze Cam v3 and the MacBook Pro were up to date with the latest firmware and software updates. This step is crucial as compatibility issues are often resolved in newer versions.
Use the Correct Cables: I discovered that the USB-C to USB-A cable I was using didn’t provide enough power. Switching to a high-quality cable with a built-in power adapter made a significant difference. This ensured the camera received a stable power supply.
Test in Windows via Boot Camp: To rule out macOS-specific issues, I booted into Windows using Boot Camp. The camera worked flawlessly there, confirming the problem was indeed macOS-related.
Adjust Camera Settings: I adjusted the camera’s settings to optimize performance. Reducing the resolution temporarily helped stabilize the connection, and I gradually increased it back to the desired level.
Reinstall Drivers and Software: Uninstalling and reinstalling the Wyze software and drivers on my MacBook Pro ensured all components were correctly configured.
After following these steps, the Wyze Cam v3 now works seamlessly with my MacBook Pro. It’s a great reminder that persistence and methodical troubleshooting can resolve even the most frustrating tech issues. I hope this helps anyone else experiencing similar problems!
