Hi everyone, I’ve been having some trouble with my Wyze Cam v3 Pro not recognizing the SD card. I initially thought it might be a card issue, so I tried a new one, but the problem persisted. After some research and troubleshooting, I found a few solutions that might help others facing the same issue.
First, ensure your camera is running the latest firmware. Sometimes, outdated software can cause compatibility issues with new hardware. I updated mine through the Wyze app, and it made a noticeable difference.
Another thing to check is the SD card formatting. I formatted the new card using the ‘exFAT’ file system, which is compatible with Wyze cameras. If you’re using a different file system, that might be the culprit.
I also discovered that some SD cards, especially those with higher storage capacities, might not be fully supported by older firmware versions. If updating the firmware doesn’t work, consider using a lower capacity card that’s known to be compatible.
Lastly, I found that resetting the camera to factory settings and then reconfiguring it helped. It seems like sometimes the camera’s settings can get corrupted, causing it to misbehave with new additions like an SD card.
I hope these tips help someone else out there. It was a bit frustrating at first, but with some persistence, I got everything working smoothly again. Happy camera setup everyone! ![]()
