After struggling for weeks to set up my Wyze Cam V3, I finally found a solution that worked! Here’s my step-by-step guide to help others facing the same issue.
Problem Overview
My Wyze Cam V3 kept stalling during the QR code setup on my home router. While other devices connected without issues, this particular camera was stubborn. I retried the setup over 50 times, following all standard troubleshooting steps, but nothing worked. Support suggested issues with my router, but since other devices connected fine, I knew it had to be something else.
The Solution
Here’s what finally worked for me:
Use a Mobile Hotspot:
- Enable your phone’s mobile hotspot (even if it’s just bridging to your home WiFi).
- Connect the Wyze Cam to this hotspot during setup.
Update Firmware:
- Once connected via hotspot, update the camera to the latest firmware. This step was crucial as it resolved the underlying issue with the router connection.
Reconnect to Home Network:
- After updating, the camera seamlessly connected to my home router without any further issues.
Why It Worked
It appears that certain firmware versions have compatibility issues with specific routers. By using a hotspot to bypass the router during setup and updating the firmware, I resolved the issue without needing to change any router settings.
Conclusion
If your Wyze Cam V3 refuses to connect, try this method. It saved me from frustration and the hassle of returning the device. Happy camera setup!
Feel free to share your own experiences or ask questions below. Let’s help each other troubleshoot and succeed!
