Wyze Camera Compatibility and Voltage Solutions
Hey everyone, I just wanted to share some insights and tips I’ve gathered while setting up my Wyze cameras and dealing with voltage compatibility issues. It’s been a bit of a learning curve, but I thought I’d pass on what I’ve learned to help others avoid some of the pitfalls I encountered.
First off, I was really impressed with the Wyze Cam Floodlight Pro. It’s been a game-changer for my outdoor security setup. However, I did run into some issues with the microSD cards. I found out that for cards larger than 32GB, it’s crucial to format them as exFAT. I wish this information was more upfront on their website, but I’m glad I stumbled upon the right format through some online research. It’s always a bit nerve-wracking setting up new hardware, but once everything was correctly formatted, it worked like a charm!
Another thing I wanted to touch on is voltage compatibility. I recently expanded my setup and was concerned about whether my devices would work with the 220V/50Hz electricity here. I was pleasantly surprised that most of the items, like the Door and Window Sensors and the Motion Sensor, are battery-powered, so they didn’t have any issues. The VeraLite was also a breeze to set up, as it supports a wide range of voltages. However, the VistaCam HD was a bit of a mystery, but after some digging, I found that it’s compatible with my setup too. It’s always reassuring when devices work seamlessly without any hiccups.
I also wanted to share a tip for anyone looking to replace their Shelly devices. I was worried that switching out an old Shelly would mean losing all my custom scenes, but I discovered that if you keep the same device ID, you can migrate the scenes without any issues. It’s such a relief to know that your hard work setting up automations doesn’t have to go to waste just because of a hardware upgrade.
On a lighter note, I’ve been experimenting with creating a DIY WiFi adapter for my SmartThings hub. It’s been a fun project, and while it’s not something I’d rely on full-time, it’s been great for troubleshooting and setting up devices on the other side of the house. It’s always satisfying to see a project come together, even if it’s just a temporary solution.
I’d love to hear from others about their experiences with Wyze cameras, voltage setups, or any clever DIY projects they’ve undertaken. The community here is fantastic, and it’s amazing how much you can learn from each other’s experiences. Thanks for reading, and happy automating!
