Wyze Camera Connection Issues with Netgear Orbi
Hey everyone! I wanted to share my experience with connecting Wyze cameras to my Netgear Orbi router. I’ve been using Wyze cameras for a while now, but I recently switched to a Netgear Orbi setup, and I ran into some connectivity issues. Let me walk you through how I resolved it!
First, I noticed that my Wyze cameras couldn’t connect to the network, even though other devices with 2.4 GHz support were working fine. After some research, I found out that this is a known issue with Wyze cameras and dual-band routers. The problem arises because Wyze cameras don’t handle the SSID overlap between 2.4 GHz and 5 GHz bands well.
I tried several troubleshooting steps, including resetting the camera, checking the router settings, and ensuring the camera was on the correct network. None of these worked initially. Then, I stumbled upon a forum post suggesting a workaround: manually setting the camera to connect to the 2.4 GHz band. Here’s how I did it:
  1. Factory Reset the Camera: This ensures a fresh start without any previous network settings.
  2. Use the Wyze App: After resetting, I used the Wyze app to add the camera to my network. I made sure to select the 2.4 GHz network explicitly.
  3. Adjust Router Settings: I also adjusted my Orbi router settings to prioritize the 2.4 GHz band for Wyze devices. This involved tweaking the router’s QoS settings to give the camera a stable connection.
After these steps, my Wyze camera connected without issues! It’s been running smoothly ever since. I wanted to share this solution in case anyone else is struggling with the same problem. It’s a bit of a hassle, but it’s definitely doable with a little patience.
If you’re still having trouble, I’d recommend reaching out to Wyze support or checking their official forums for updates. I’m hopeful that Wyze will address this compatibility issue in future firmware updates. Happy connecting everyone!
