Hi everyone, I’m facing a peculiar issue with my Wyze cameras and I’m hoping someone might have some insights or solutions. For the past couple of weeks, I’ve noticed that while my cameras detect motion, they don’t record the events or log them in the events tab. This is quite puzzling because I’ve tested the motion detection feature, and it does seem to pick up movement correctly. However, no recordings or logs are generated, which is a significant inconvenience for me.
I have a mix of Wyze Cam V3s, a Pam Cam V1, and a Doorbell Pro. The issue seems to be consistent across all my Wyze cameras except for the Doorbell Pro, which works as expected. I’ve tried the usual troubleshooting steps—rebooting the cameras, resetting them to factory settings, and reconfiguring them. Unfortunately, none of these steps have resolved the problem. I’ve also reached out to Wyze support, but their response has been less than helpful, to say the least.
One thing I noticed is that the problem started around August 3rd, which makes me wonder if it’s related to a firmware update or some change in the app’s functionality. I’m currently on the latest firmware versions for all my cameras, and the Wyze app is also up to date. I’m also using a Cam Plus subscription for two of my cameras, but that hasn’t made a difference either.
Does anyone else have similar issues? Has anyone found a workaround or a solution? I’m starting to think it might be a broader issue with the Wyze ecosystem, but I’m not sure. Any advice or suggestions would be greatly appreciated. Let’s hope we can figure this out together!
