Wyze Camera Playback Issues and Solutions
Hey everyone, I wanted to share my experience with the Wyze camera playback feature. I’ve been using Wyze cameras for a while now, and recently I noticed some issues with the playback functionality. It’s been a bit of a journey to figure out what’s going on and how to fix it, so I thought I’d document my findings here in case anyone else is experiencing similar problems.
Initially, I set up three Wyze cameras with 32GB SD cards, configured to record events only. Everything seemed to be working fine for a few days, but then I started having trouble accessing the playback feature. When I tried to view past recordings, the screen wouldn’t change from the live feed, and I couldn’t see the recorded events. It was pretty frustrating, especially since I rely on these cameras for security.
I reached out to Wyze customer support, and they suggested removing the SD card, unplugging the camera, and then reinserting everything. They also recommended restarting the Wyze app. After doing this, the issue persisted, so I decided to take matters into my own hands.
I tried reformatting the SD card and switching the camera to continuous recording mode. To my relief, the playback feature started working again. It seems like the combination of reformatting the card and changing the recording settings made a difference. I’m not entirely sure why this worked, but I’m glad it did!
If anyone else is having trouble with their Wyze camera playback, here are a few tips that might help:
  1. Check the SD Card: Make sure the SD card is properly formatted and compatible with your camera. I’ve heard that some cards can cause issues, so experimenting with different brands might be worth it.
  2. Update Firmware: Ensure your camera’s firmware is up to date. Sometimes, bugs in the firmware can cause unexpected behavior.
  3. Change Recording Settings: If event-only recording isn’t working, try switching to continuous recording. It might give the playback feature the stability it needs.
  4. Reset and Reboot: Don’t underestimate the power of a good old-fashioned reset. Unplugging the camera, removing the SD card, and starting fresh can often resolve hidden issues.
  5. Contact Support: If all else fails, reach out to Wyze support. They might have additional troubleshooting steps or insights into the problem.
Overall, while the playback issue was a bit of a setback, it’s reassuring to know that there are solutions out there. I’m back up and running now, and I’m more confident in my setup than ever. If anyone has any other tips or experiences to share, I’d love to hear them!
Cheers,
