Hey everyone, I wanted to share some tips and tricks I’ve learned while setting up my Wyze cameras. First off, I struggled a bit with the Docker config for the Wyze API keys, but it turned out to be much simpler than I expected. Here’s a quick rundown of what worked for me:
Docker Setup: If you’re using UnRaid, make sure to add the API_ID and API_KEY variables in the Docker container settings. It’s a straightforward process once you know where to look!
Dashboard Cloning: I was also curious about cloning dashboards. After some digging, I found that while there isn’t a direct ‘clone’ button, you can manually recreate dashboards by copying settings and layouts. It saves a lot of time, especially if you need multiple dashboards for different family members.
Wyze Camera Placement: Speaking of cameras, I recently installed a Wyze Cam and noticed some interference issues with my X-10 devices. Turns out, replacing the power adapter solved the problem. Now, my cameras work seamlessly without affecting my other smart home devices!
Humidity Sensor Automation: I’ve been experimenting with automating my hydroponic setup using a Wyze Cam and a humidity sensor. It’s been a learning curve, but setting up rules to control the humidifier based on specific humidity levels and times has been a game-changer. My strawberries are thriving!
Firmware Updates: If you’re experiencing any issues with your Wyze devices, make sure to check for firmware updates. Sometimes, a simple update can resolve connectivity or performance problems.
I hope these tips help someone out there. Let me know if you have any questions or if you’ve discovered any cool tricks of your own! ![]()
