Wyze Camera Stability Tips and Tricks
Hey everyone, I wanted to share my experience with the Wyze cameras and some tips I’ve picked up along the way. I’ve been using Wyze cameras for a while now, and while they’re generally great, I’ve noticed some firmware update quirks that can be a bit frustrating. For instance, whenever I try to update the firmware, the cameras often go offline, requiring a hard reboot or even a complete setup from scratch. It’s a bit of a hassle, but I’ve found a few workarounds that make things smoother.
First, I’ve started scheduling firmware updates during times when I’m actively monitoring the cameras. This way, if something goes wrong, I can address it immediately instead of discovering the issue later. I’ve also noticed that keeping the camera app updated on my phone helps with stability. It might seem obvious, but sometimes a simple app update can make a world of difference.
Another tip I’ve come across is to use a reliable power source for the cameras. I’ve started using USB hubs with built-in surge protection, which has significantly reduced the number of unexpected reboots. If you’re experiencing similar issues, I highly recommend giving this a try.
I’d love to hear how others are handling firmware updates and maintaining camera stability. Have you found any tricks or workarounds that make the process smoother? Let’s share our experiences and help each other out!
Cheers,
