I recently encountered an issue with my Wyze color bulbs after moving them to my vacation home. The bulbs wouldn’t connect to the Wyze app, which was quite frustrating. After some research and troubleshooting, I found a few solutions that might help others facing similar problems.
First, ensure that your bulb is properly reset. Sometimes, moving the bulb can disrupt its connection, and a factory reset can help re-establish the link. To reset, hold down the button on the bulb for about 10 seconds until the light starts flashing. Then, try adding it to your app again.
Another thing to check is your Wi-Fi network. If you’re on a different network, sometimes the app has trouble connecting. I found that manually entering the bulb’s IP address in the app helped, though this can be a bit technical.
Additionally, consider updating the Wyze app to the latest version. Sometimes, bugs are fixed in newer releases, and an update might resolve connectivity issues.
Lastly, if you’re using multiple Wyze devices, ensure they aren’t overcrowding your network. Sometimes, too many devices can cause connectivity problems. If possible, try adding one bulb at a time to see if the issue persists.
I hope these tips help others who are experiencing similar issues with their Wyze bulbs. It was a bit of a hassle, but with some patience and troubleshooting, everything started working again!
