Wyze Doorbell Issues and Solutions
Hey everyone, I’ve been having some trouble with my Wyze doorbell lately, and I wanted to share my experiences and some solutions I’ve found. Hopefully, this can help others who might be facing similar issues!
First off, my doorbell stopped working properly. It wouldn’t chime or alert Alexa when someone pressed it initially. It was frustrating because it felt like the doorbell was just ignoring me. After some research, I discovered that the issue might be related to the doorbell needing a bit of time to ‘wake up’ after being pressed. I tested this theory by pressing the doorbell a few times in a row, and sure enough, the second press worked like a charm! It’s like the doorbell needs a moment to connect to the WiFi before it can send notifications. I was relieved to find this workaround, especially since the doorbell is located very close to my router, so I didn’t think distance was an issue.
Another thing I noticed was that the video quality from my Wyze Cam v3 had deteriorated significantly. The footage was filled with artifacts, and the brightness wasn’t what it used to be. I wondered if this was a firmware update issue or a hardware problem. After some digging, I found that increasing the compression algorithms might be the culprit. I considered flashing the firmware to an older version, like RTSP_4.61.0.1, but I wasn’t sure if that was the best move. I decided to stick with the current firmware for now and see if the issue persists.
For those who might be experiencing similar problems, here are a few tips:
  • Check the Doorbell Placement: Ensure the doorbell is positioned correctly and not obstructed by anything.
  • Test Multiple Presses: If the doorbell doesn’t respond on the first press, try pressing it again.
  • Update Firmware Carefully: If you’re considering a firmware rollback, make sure it’s stable and compatible with your device.
  • Inspect Lighting Conditions: Ensure there’s adequate lighting around your doorbell to improve video quality.
It’s been a bit of a rollercoaster trying to troubleshoot these issues, but I’m glad I’ve found some temporary solutions. I’m hopeful that Wyze will address these concerns in future updates. If anyone has additional tips or experiences to share, I’d love to hear them!
Cheers,
