Wyze Doorbell Wedge Angle Adjustment Solution
I recently faced an issue with my Wyze doorbell’s angle, which was not optimal for my setup. After some research and experimentation, I found a creative solution that might help others in similar situations. Here’s my story:
Initially, I installed the Wyze doorbell on a wall that wasn’t perfectly aligned with my entrance. The existing wedge provided a slight angle adjustment, but it wasn’t enough to make the doorbell face directly outward. This meant that the camera’s field of view wasn’t ideal, and I couldn’t capture the full area I wanted to monitor.
After some trial and error, I discovered that adding a small, custom-cut piece of foam rubber behind the doorbell mount helped achieve the desired angle. This simple fix not only improved the camera’s alignment but also ensured that the doorbell looked neat and professional. I’m thrilled with the result and now have a clear view of my entrance!
If anyone else is dealing with a similar issue, I recommend trying this approach. It’s a cost-effective and easy solution that doesn’t require any advanced tools or skills. Happy tinkering! :rocket:
