Wyze Floodlight Installation and Usage Experience
I recently decided to purchase the Wyze floodlight camera after being impressed with the performance of my existing Wyze cameras. The idea of having a camera/light combo sounded appealing, especially for enhancing security around my property. However, the installation process turned out to be more challenging than I anticipated, and I wanted to share my experience in case it helps others.
Installation Challenges
The base diameter of the Wyze floodlight is 5 inches, which doesn’t align with the standard 4-inch round electrical boxes commonly found in homes. My electrical box is surface-mounted, which compounded the issue. Initially, I thought about returning the product due to this setback, but I decided to give it a try by creating a custom adapter plate. I used a piece of ¼-inch lexan, cut it to a 5 ¼-inch diameter, and mounted it securely to the electrical box. This makeshift solution worked perfectly, allowing me to mount the floodlight above my garage doors facing the street.
Usage and Performance
The floodlight itself is bright and effective, and the integrated camera works seamlessly, powered by the light without needing additional wiring. The camera’s performance has been consistent, and I appreciate the continuous recording feature, which I can review through the Wyze app.
However, I’ve encountered some issues with the PIR motion sensor. Initially set to maximum sensitivity, the sensor triggered the light frequently, even when there was no apparent movement in its field of view. After several weeks of use, I’ve had to reduce the sensitivity to 50%, which has somewhat mitigated the problem, though occasional false triggers still occur.
Conclusion
Overall, I’m satisfied with the Wyze floodlight camera, especially considering its price point. The light is bright, the camera integration is smooth, and the continuous recording feature is a bonus. However, potential buyers should be aware of the installation challenges, particularly if their electrical boxes don’t match the floodlight’s base diameter. Additionally, the motion sensor’s sensitivity might require adjustment based on your environment.
If you’re considering this product, I’d recommend thoroughly checking your electrical box setup and being prepared to create an adapter if necessary. Happy installing!
