Hey everyone, I wanted to share my experience with the Wyze Light Strip Pro after some confusion about the number of segments. Initially, I was a bit puzzled by the product description and reviews, wondering if each 16.4" strip had 8 or 16 controllable segments. After some research and hands-on testing, I figured it out and thought I’d walk through my journey in case it helps others!
First, I started by reading through the product page and customer reviews. Some mentioned 8 segments per strip, while others referred to 16 segments when using the longer 32.8" model. I decided to test this myself by purchasing a 32.8" strip and connecting it to my smart home system. The setup was straightforward—just plug it in and let the Wyze app detect it automatically.
Once paired, I opened the Wyze app and navigated to the device settings. To my delight, I could individually control each of the 16 segments! This was perfect for my living room setup, where I wanted different lighting effects across the length of the strip. I even created a few scenes to switch between different color schemes with a single tap.
For those still unsure, here’s a quick tip: when you add the strip to your Wyze app, go into the device details and check the supported features. It clearly lists the number of segments and the range of colors you can control. This feature is especially handy for larger spaces or creative lighting designs.
I also found that the app’s color picker and preset options made experimenting with different looks a breeze. Whether I wanted a subtle gradient or a vibrant display, the Wyze Light Strip Pro delivered beautifully. Plus, the energy efficiency is impressive, which is a big plus for eco-conscious users like me.
In summary, if you’re on the fence about the Wyze Light Strip Pro, especially regarding the number of segments, give it a try! It’s a versatile and user-friendly addition to any smart home setup. Happy lighting! ![]()
