Hey everyone, I wanted to share my experience with the Wyze Lock and some troubleshooting tips I’ve come across. Recently, I noticed that my Wyze Lock was having trouble with the auto-unlock feature. It would emit a high-pitched beep, try to unlock partially, and then get stuck, sending a door jam alert to my phone. This was pretty frustrating, especially since manual unlocking worked fine.
I started by checking the lock mechanism and strike plate, but everything seemed fine. I also tried resetting the lock multiple times without success. After some research, I found that others were experiencing similar issues, and it seemed to be related to the auto-unlock process rather than manual operations.
Here are some steps I took to troubleshoot:
- Manual Lock/Unlock Test: I used the PIN pad to lock and unlock the door manually. This worked perfectly, which suggested the issue was specific to the auto-unlock feature.
- Firmware Update: I checked for any available firmware updates for the Wyze Lock. While there wasn’t a direct fix for this issue, keeping the firmware up to date is always a good practice.
- Contact Support: I reached out to Wyze support, and they mentioned they were aware of the issue and working on a fix. They also recommended monitoring the Wyze app for updates.
- Community Solutions: I found some helpful tips in the Wyze community forums, such as ensuring the lock is fully engaged before triggering auto-unlock and avoiding quick movements that might interfere with the mechanism.
If anyone else is experiencing similar issues, I hope these tips help. It’s a bit frustrating, but knowing others are going through the same thing makes me feel a bit better. I’m hopeful Wyze will resolve this soon. Let me know if you’ve encountered this problem or have any additional solutions to share!
