Hi everyone, I wanted to share a quick fix I discovered for my Wyze Lock not recognizing new batteries. It was frustrating because I knew the batteries were good, but the lock just wouldn’t register them. After some research and trial and error, here’s what worked for me:
Locate the Update Button: On the base unit near your lock, there’s a small, round button. This is crucial for re-syncing the lock with the new batteries.
Hold Until Flashing: Press and hold that button until you see the lights start flashing red and green. This indicates the lock is entering update mode.
Reconnect to Wi-Fi: Once it’s flashing, release the button and let it reconnect to your home network. It should automatically start working again without any further issues.
This simple fix saved me from having to replace the entire lock unit, which would have been a hassle and more expensive. I hope this tip helps anyone else experiencing the same problem!
If you have any other questions or need troubleshooting advice, feel free to reach out. Happy smart home hacking! ![]()
