Hey everyone, I just wanted to share my experience installing the Wyze Lock on my front door. I’ve seen a few posts where people were unsure about the clearance requirements, so I thought I’d walk through my process and offer some tips that might help others!
First off, my door has the internal deadbolt lock positioned about 1.5 inches above the handle. I was a bit concerned this might be too close for the Wyze Lock to function properly, but after installation, it’s been working like a charm! The key here was ensuring the lock mechanism had enough space to move without any interference.
For anyone planning to install a Wyze Lock, I’d recommend a few things:
- Measure Twice: Before drilling, double-check the distance between the handle and the lock mechanism. A small discrepancy can make a big difference!
- Use the Right Tools: Invest in a good drill and bit set. The alignment of the holes is crucial for a smooth installation.
- Lube It Up: A little WD-40 on the lock mechanism can work wonders. It helps everything glide smoothly, especially if the door has any play in it.
- Check for Play: If your door has a lot of movement, make sure the lock isn’t hitting any part of the frame. A quick adjustment of the hinges can make all the difference.
- Test Early: Once the lock is in place, test it out by cycling the deadbolt a few times. This helps ensure everything is aligned correctly before you finish the installation.
One thing I did differently was to use a small mirror to check the alignment of the drill holes. It might sound a bit geeky, but it made the process much easier!
If you’re still unsure about the clearance, I’d recommend reaching out to Wyze support. They were super helpful when I had a few questions before starting the installation.
All in all, the Wyze Lock has been a fantastic addition to my smart home setup. It’s reliable, integrates seamlessly with my existing ecosystem, and the app controls are a breeze to use. If you’re on the fence about making the switch, I’d say give it a shot—you won’t regret it!
Happy installing, and feel free to drop a comment if you have any questions or tips of your own. ![]()
