Hey everyone, I wanted to share my experience with mounting the Wyze Motion Sensor. I’ve been using it for a while now, and it’s a fantastic device for monitoring my home. However, finding the right way to mount it without damaging my walls or compromising the sensor’s functionality was a bit of a challenge. Here’s what I discovered!
The Challenge
I’ve tried a few different mounting solutions in the past, but none seemed to fit perfectly. I wanted something that was both secure and aesthetically pleasing. After some research and experimentation, I stumbled upon a couple of products that worked wonders.
The Solution
Velcro Hangables Small Hooks: These hooks are almost the perfect width to adhere to the backside of the Wyze Motion Sensor. They come with Command Strip-style adhesives, which are great for temporary or semi-permanent installations. The hooks are slightly angled, which helps in positioning the sensor at the optimal angle.
Ook Picture Hangers: For a more permanent solution, I opted for these large brass-plated picture hangers. They provide a sturdy base and allow for precise angle adjustments. I used Velcro Removable Wall Fasteners to secure the sensor to the hanger, ensuring a clean and secure mount.
The Results
Both solutions worked exceptionally well, but the Ook hangers with Velcro fasteners proved to be the most versatile. I was able to paint the hangers to match my wall color, making them almost invisible. The cost was minimal—around $1.50 per mount, including adhesives. Plus, the process was straightforward and didn’t require any specialized tools.
Tips for Others
- Angle Adjustment: Don’t be afraid to tweak the angle of the hanger slightly. This can make a big difference in the sensor’s coverage area.
- Adhesive Placement: Make sure to place the Velcro squares inside the padded circle on the sensor’s back to ensure a clean and secure adhesion.
- Painting: If you’re using metal hangers, consider painting them to match your wall color. It adds a professional touch and blends seamlessly into your decor.
I’m thrilled with how this turned out. The Wyze Motion Sensor is now securely mounted, and it blends perfectly with my home’s aesthetic. I hope this helps others who are looking for a reliable and stylish mounting solution for their Wyze devices. Happy mounting! ![]()
