Wyze Plug Connection Troubleshooting and Solutions
I recently purchased the Wyze Plug and have been experiencing some connectivity issues when using Alexa to control it. Every time I try to turn it on or off, the connection drops, and it takes several restarts of my phone to reconnect. This has been quite frustrating, especially since my security camera, which is also connected to the same network, doesn’t have this issue. I was hoping to get the Wyze bulbs as well, but I’m worried about encountering the same problem.
After some research, I found that others have had similar issues with the Wyze Plug. It seems like a common problem, but there are some solutions that might help. One user suggested resetting the plug and重新配对 it, which worked for them. Another tip was to ensure that the plug is on a stable power source and not experiencing any voltage fluctuations. I also came across a forum where someone mentioned updating the Wyze app to the latest version, which apparently fixed the issue for them.
If you’re having trouble with your Wyze Plug, here are a few steps you can try:
  • Reset the Plug: Hold the button until the light starts flashing, then release and let it reset.
  • Check the Network: Ensure your Wi-Fi is stable and the plug is within range.
  • Update the App: Make sure you’re using the latest version of the Wyze app.
  • Factory Reset: If all else fails, perform a factory reset on the plug.
I hope these tips can help someone else avoid the frustration I’ve been feeling. Let me know if you’ve found any other solutions or if you’ve had success with these steps! :blush:
