I’ve been exploring the capabilities of my Wyze plug and came across a question about integrating it with Wyze cam for motion detection. After some research and experimentation, I’d like to share my findings and tips for anyone looking to set this up!
First, I wanted to automate my Wyze plug to turn on and off based on motion detected by my Wyze cam. I discovered that while the Wyze app allows for some automation, it doesn’t natively support direct integration between the plug and cam for motion detection. However, with a bit of setup using IFTTT or a similar automation service, it’s completely doable!
Here’s a quick rundown of what I did:
IFTTT Integration: I created an applet in IFTTT where the Wyze cam’s motion detection triggers a command to turn the Wyze plug on or off. It was surprisingly straightforward once I connected both devices to my IFTTT account.
Testing Scenarios: I tested different scenarios, like turning on lights when motion is detected and turning them off after a period of inactivity. This was perfect for my hallway, where I wanted lights to come on automatically but not stay on all night.
Customization: I also explored using voice commands through my smart speaker to override the automation if needed. This added a layer of flexibility that I really appreciate.
Energy Efficiency: One thing I noticed is that automating the plug not only adds convenience but also helps in managing energy consumption. It’s a small way to contribute to energy efficiency!
If you’re looking to set this up, I’d recommend starting with a simple automation and gradually adding more complex scenarios as you get comfortable. The key takeaway is that while native integration might not be available, there are plenty of workarounds to achieve the functionality you’re looking for!
I’d love to hear how others have integrated their Wyze devices or if there are other methods you’ve found effective. Let’s keep the tips flowing! ![]()
