Wyze Sensor Automation with Alexa: A Smart Solution
Hey everyone, I’m really excited to share a clever workaround I discovered for integrating Wyze sensors with Alexa. I’ve been experimenting with smart home automation, and one thing that’s been on my mind is how to get Alexa to take action when a contact sensor is left open. I stumbled upon this issue because my Wyze sensor only allows open/close triggers, which didn’t quite meet my needs.
After some research and tinkering, I found a neat solution that doesn’t require any third-party integrations. Here’s how it works:
  1. Name your Wyze plug: I named mine “Alexa Trigger”.
  2. Create a Wyze rule: Set the trigger to “contact sensor open for X minutes” and action to turn on the “Alexa Trigger” plug.
  3. Set up an Alexa routine: Use the plug’s activation as the trigger. When the plug turns on, Alexa can perform any action you want, like making an announcement or turning off the plug to reset the system.
This setup has been a game-changer for me, especially for monitoring my garage door. It’s such a relief to know that Alexa will notify me if the door stays open too long. Plus, it’s satisfying to see everything work seamlessly without needing extra hardware.
I’d love to hear if others have found similar solutions or have any tips to make this even more efficient. Let’s keep the creativity flowing! :rocket:
