Wyze Strip Lights Syncing Tips and Tricks
Hello everyone! I wanted to share some tips and tricks I’ve discovered while working with my Wyze Strip Lights. A while back, I noticed that my OG and Pro Strip Lights weren’t syncing perfectly after resetting them due to a change in my Wi-Fi router. It was a bit frustrating, but I managed to figure out a workaround that might help others in similar situations.
First, I tried turning the lights on and off in sync, but that didn’t always work. I also experimented with music mode and auto-color settings, which used to work perfectly before the reset. After some trial and error, I found that using specific auto-on/off rules in the Wyze app helped me get the lights back in sync. It’s not a perfect solution, but it’s reliable enough for my needs!
Here’s a quick tip for anyone struggling with syncing: Make sure your Wi-Fi signal is strong where your lights are placed. Weak signals can cause delays or syncing issues. Also, try resetting both lights individually before grouping them again. Sometimes a fresh start helps!
I’d love to hear if anyone else has found a more seamless way to sync their Wyze Strip Lights. Let’s keep the conversation going and share our experiences! :blush:
