Hey everyone, I wanted to share a quick tip that might help those of you who’ve encountered the blue light issue with Wyze switches, especially in bedrooms. I had one in my main bedroom, and it was quite the nuisance waking up to that bright blue flash in the middle of the night! ![]()
After some research, I found that the blue light is triggered when the device loses its internet connection. While it’s a helpful indicator, it’s not ideal for sleep hygiene. Here’s what I did to fix it:
Relocate the Switch: I moved the switch to a less prominent area where the blue light wouldn’t disrupt my sleep. If relocation isn’t an option, consider using a cover or placing it behind furniture.
Adjust Placement: Ensure the switch isn’t near your bed or in a direct line of sight from where you sleep. This simple change made a world of difference for me!
Use a Smart Plug: If you’re using the switch for a lamp or appliance, consider pairing it with a smart plug. This way, you can control the device without the switch needing to be in your bedroom.
Check Wi-Fi Connectivity: Sometimes, the blue light is a sign of a weak or unstable connection. Ensuring your Wyze devices have a strong, consistent Wi-Fi signal can prevent unnecessary flashes.
Alternative Solutions: If the blue light is unavoidable, you might want to explore other brands or models that offer customizable indicators or silent notifications.
This experience taught me the importance of considering all aspects of a smart device, including how it affects daily routines like sleep. I hope these tips help someone out there who’s dealing with the same issue! ![]()
Let me know if you’ve found other creative solutions to this problem. Happy automating! ![]()
