I wanted to share my experience with integrating the Wyze Thermostat with my external wood boiler system. This setup has been a game-changer for my home heating during the winter months. **Here’s the story:**For years, I relied solely on my forced-air furnace for heating, but during the colder months, I switched to an external wood boiler system. The challenge was getting the Wyze Thermostat to work seamlessly with this setup. I only use the furnace for a couple of weeks, so the boiler takes over as the primary heat source.Initially, I struggled with getting the fan to activate when needed. After some research and trial and error, I discovered a workaround. By adjusting the thermostat settings and using some smart home automation rules, I managed to get the fan to kick on automatically when the boiler system signals that heat is required. This integration ensures that my home stays warm without manual intervention.Key Takeaways:- Compatibility: The Wyze Thermostat is surprisingly compatible with external heating systems if you’re willing to tweak settings.- Automation: Using smart home automation rules can bridge the gap between different heating systems.- Research: Don’t hesitate to dive into forums and documentation for solutions. There’s a wealth of knowledge out there!This setup has made my winters much more comfortable, and I’m excited to see how this integration evolves in the future. If anyone else is looking to combine their Wyze Thermostat with an external heating system, I’d be happy to share more details or tips!
