I’ve been a long-time user of Wyze products, and I must say, they’ve always impressed me with their reliability and affordability. However, my recent experience with integrating a Wyze thermostat in a new home with an interconnected HRV system has been quite the learning curve. Let me share my journey and hopefully, it can help others facing similar issues.
The Setup:
I installed a Wyze thermostat in a newly built home equipped with an electric high-efficiency furnace, A/C, and an interconnected HRV system. The installation seemed straightforward, following the provided instructions, including adding a C module for power. Initial testing of both heat and cool functions worked perfectly, which was reassuring.
The Problem:
Later that day, I noticed the thermostat had gone offline—no display, no response to button presses, and the app indicated it was offline. After attempting standard troubleshooting steps like power cycling and reinstalling the app, the issue persisted. Upon closer inspection, I realized the HRV’s fan control circuit was intercepting the G circuit of the thermostat, causing a conflict.
The Discovery:
Through extensive checking, I inadvertently discovered that turning off the HRV powered the thermostat back on. This led me to hypothesize that the HRV’s operation was causing a voltage drop, preventing the thermostat from functioning correctly. The HRV, when powered on, seemed to draw enough current to reduce the 24V supply to around 5V, which is insufficient for the thermostat.
The Solution:
After some research and trial, I found that connecting an additional spare wire between the furnace and thermostat terminals to the C terminal on both ends resolved the issue. This provided a stable power supply, allowing the thermostat and HRV to coexist without interference.
Key Takeaways:
- Power Supply Stability: Ensure that the C wire is correctly connected and that there’s no voltage drop caused by other devices sharing the same circuit.
- HRV Integration: Be cautious when integrating HRV systems with smart thermostats, as they can share control circuits that may conflict.
- Testing and Documentation: Thoroughly test each component and document any unusual behavior to pinpoint issues quickly.
This experience reinforced my appreciation for Wyze products, despite the initial hurdles. It also highlighted the importance of understanding the interactions between different smart home components. I hope this account helps others navigate similar challenges and emphasizes the value of careful installation and troubleshooting.
Happy smart home tinkering everyone! ![]()
