I’ve been really impressed with my Wyze thermostat and humidifier setup!
I wanted to share my experience in case anyone else is looking to integrate these devices into their smart home setup. After setting up my Wyze thermostat, I noticed how smoothly it controls the heating in my room. I created a rule where the humidifier outlet turns on when the heat kicks in, which has been working perfectly. However, I ran into a small issue where the humidifier stayed on even after the furnace turned off. Thankfully, the Wyze community was super helpful! They explained that while there isn’t a direct “stop heating” trigger, there are workarounds using schedules or additional sensors. I ended up using a simple timer to turn off the humidifier after the furnace stops, and it’s been working like a charm ever since. This experience has made me even more confident in Wyze products. Their integration with other smart devices is seamless, and the support community is amazing. If you’re thinking about adding a thermostat or humidifier to your setup, I highly recommend giving Wyze a try! ![]()
