Hey everyone, I wanted to share a tip that might help others who are using the Wyze thermostat to control dual fan speeds. I recently encountered a situation where I needed to switch between two fan speeds for better humidity control and cooling efficiency. After some research and trial and error, here’s what worked for me:
Understanding the Wiring: First, I made sure to correctly identify the G wire and the orange wire for the second fan speed. It was crucial to understand how these wires were connected to the thermostat.
Configuration in the Wyze App: I discovered that while the Wyze thermostat doesn’t natively support dual fan speeds, there’s a workaround. By adjusting the fan speed settings within the app, I could specify when to use the lower or higher fan speed based on my needs.
Testing and Fine-Tuning: I spent some time testing different configurations to ensure the thermostat switched between the fan speeds as intended. It was a bit tricky, but persistence paid off!
I hope this helps someone who’s looking to optimize their HVAC system with the Wyze thermostat. If you have any questions or need further clarification, feel free to ask!
Happy tinkering! ![]()
